Incorrect Specific Heat Value when I used a Polynomial or the Kinetic Theory
Old   February 26, 2021, 13:47
Default Incorrect Specific Heat Value when I used a Polynomial or the Kinetic Theory
CWL
cwl6750084 is on a distinguished road
I tried to insert the constant pressure specific heat of water vapour along the saturation curve from the steam table. However, the values computed from Fluent is about 300 J/kg-K higher than values given by the steam table. I switched to the piecewise-liner option and inputted the tabulated values, the same happens.
Moreover, when I used the kinetic theory for specific heat. I used 9 as the degree of freedom for water. However, now, the computed specific is too small and I have to use 12 as the degree of freedom in order to obtain the correct values. Is Fluent counting the degree of freedom the same way as in Physical Chemistry textbook?
Any assistances are appreciated. Thanks.
cwl6750084 is offline   Reply With Quote
Continuity Equation for multicomponent simulation lordluan CFX 15 May 19, 2020 18:36
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
poor calculation with temparture-dependant specific heat ryanmoser FLUENT 3 January 3, 2013 01:32
Polynomial coefficients for specific heat of Ideal gas avi031 Main CFD Forum 0 November 11, 2011 00:28
