March 5, 2021, 07:52 |
Dynamic Mesh - Layering
I have a query relating to the implementation of a dynamic mesh on a sloped wall. Background: I am simulating the extrusion of two stacked glasses through a die. The vertical wall entitled "piston" is moved using a profile to simulate the glass being pushed through the die (Screenshot 2021-03-05 at 12.38.24.jpgScreenshot 2021-03-05 at 12.38.07.jpg). I use the layering method within the dynamic mesh and specify a cell height equal to the width of each cell. Since the geometry is fairly simple, the mesh and each individual cells width is uniform within the section I want to move. I have managed to successfully run this geometry and I am happy with the results Next, I would like to model a similar geometry, however instead a vertical "piston" wall, this time the wall is tapered (Screenshot 2021-03-05 at 12.14.05.jpgScreenshot 2021-03-05 at 12.13.53.jpgScreenshot 2021-03-05 at 12.51.17.jpg) to see how this impacts the glass being extruded. However, with a tapered wall the mesh cells become skewed as you move down the geometry. This means the cell height of each adjacent cell is not equal and so when the cells are merged they aren't merged equally. Does anyone have any suggestion for a solution to this? I am quite new to Fluent, so please excuse any poor terminology. If there is any information I have missed which would help in solving my problem please ask. Thanks |
Interfoam and dynamic mesh with layering (OF1906) | nkalkote | OpenFOAM Running, Solving & CFD | 0 | July 17, 2019 01:57 |
Dynamic Mesh | kennyboy | FLUENT | 1 | February 23, 2019 01:52 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
