Particle Injection File
Old   March 10, 2021, 10:29
Default Particle Injection File
Abi
Abeer is on a distinguished road
Hello everyone,
I am trying to simulate the motion of solid particles in a cylinder filled with air in ANSYS FLUENT. but it was difficult to insert the particles in different size (1 mm &1 cm) into the domain. I want them to be already present in the domain at t=0 with random initial distribution.
I want to perform particle tracking in the Lagrangian frame after different intervals of time.
I have inserted the particle using injection file, but for uniform particle diameter and distribution. It is possible to add 200 particles in different diameter with a random initial distribution and radial initial velocity in the domain without having to inject them.
Thanks in advance.!
Abeer is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
