Transient .dat file not linking to .cas file (CFD-post/FLUENT) |
March 13, 2021, 18:27 |
qntldoql
Rep Power: 5 |
Hi, this might be a silly question, but I have a problem with viewing transient .dat files using CFD-post.
I am currently simulating a transient simulation using a HPC. Before this, when I ran the simulation on my workstation (2ddp), it saved .cas and .dat files as following: example.cas example-00100.dat example-00200.dat ... and I could view the transient results by simply by opening the .dat files via CFD post. But when I try the same with the .dat file I obtain from the HPC, it requires exact same name of .cas file to read the .dat file via CFD-post. (to read example-00100.dat file, it needs example-00100.cas file) I have both the original .cas file (example.cas) and transient results all in the same folder. What could be causing this problem and how would I solve it? As you can imagine, it causes a lot of inconvenience creating each .cas file for each .dat file. Thank you in advance! |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
