Facing problems with material adding in Fluent |
March 17, 2021, 19:22 |
Sulman Saeed
Hi buddies, I am doing a Fluent analysis and facing some issues regarding adding material properties in Fluent. You can see in the pictures below:
In these pictures, you can clearly see that whenever I add new material and then its specific heat and thermal conductivity are not showing. I have to change the thermal conductivity and specific heat according to my selected material but these properties are not loading/available/showing for making changes. Plz, help me to sort out this issue. I am very grateful to you for it. Also in the boundary conditions, I cannot change the thermal properties like temperature, etc. because this option is not available there. I have uninstalled and then reinstalled Ansys thrice (3 times) plus change the Ansys version but it did not work. Screenshot (16).jpg Screenshot (17).jpg Screenshot (18).jpg Screenshot (20).jpg Screenshot (19).jpg |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
multiRegionHeater error | ordinary | OpenFOAM Running, Solving & CFD | 2 | June 9, 2020 17:43 |
Add Young's Modulus and Poisson Ratio to a material into Fluent | florian.crepin | Fluent UDF and Scheme Programming | 4 | April 30, 2019 13:04 |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
Fluent is not accepting Modification in Material properties | er.mkumar | FLUENT | 0 | September 1, 2012 14:24 |
