April 7, 2021, 06:28 |
Application Failed to Connect
East Borneo
Rep Power: 5 |
Dear friends,
I got problem while to open Results on the Fluent-Workflow and show pop up window as Application Failed to Connect. Can anyone help me to solve this problem? Thank you very much Best regard Binyamin |
April 7, 2021, 10:54 |
Lucky
Rep Power: 66 |
See error #5. The project did not save and update.
April 7, 2021, 20:26 |
East Borneo
Rep Power: 5 |
I've already update the Solution, but still shown like that
April 8, 2021, 03:50 |
Lucky
Rep Power: 66 |
Hi. Please see my post #2. The project file did not save. That's why the update failed. Errors #4 and #3 give hints that there is an invalid file path and path being too long for it to save. If you look at the console output, the case and data file were also not saved after the calculation was complete. That's also peculiar...
April 8, 2021, 05:18 |
East Borneo
Rep Power: 5 |
Thanks for your response, I'll try to check it
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
