Intermixing of two miscible liquid fluids in T-pice with Ansys Fluent
Old   April 15, 2021, 17:26
Smile Intermixing of two miscible liquid fluids in T-pice with Ansys Fluent
Helge
CFD Flow is on a distinguished road
Hi guys, I am relatively new to CFD and Ansys Fluent.
I am trying to create a model to mix two different miscible, incompressible fluids together in a T-piece.
The solvents are THF (tetrahydrofurans, 980.9 kg/m3, 0.00185 kg/m/s) and Et2O (diethyl ether, 809.2 kg/m3, 0.000845 kg/m/s) at -70°C.
The flow is laminar Re<10
The condition is steady-state
I would select the following parameters:
Type --> Pressure based
Time --> Steady
Energy -- > On
Viscous --> Laminar
Model --> Species transport
From here on I do not get any further. I don't know which properties to insert in the mixture template so that the density and the viscosity of the mixture fluid can be calculated in each point depending on the volume fraction of THF. In the publication I am trying to reproduce, a UDF was used for this. Can someone help me from here on to solve the problem?
The paper I am trying to reproduce the model from is: Science 2016, 352, 691, DOI: 10.1126/science.aaf1389
I appreciate any help!
CFD Flow is offline   Reply With Quote
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 17:07
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
simulating liquid metal in Fluent Shamoon Jamshed FLUENT 0 October 11, 2014 11:15
Ansys structural and fluent for FSI assafwei FLUENT 1 June 20, 2014 10:56
Fluent & Ansys FSI architecture help DillonS FLUENT 1 April 7, 2010 16:00
