how can i fix reverse flow? jet impigment 3d modelling
Old   April 28, 2021, 17:13
Smile how can i fix reverse flow? jet impigment 3d modelling
Mauro Killary
maurokillary13 is on a distinguished road
In context i'm simulating a 3d inclined plane, jet impigement, i decided to use this approach due to in next steps of my work i need to evaluate particle trajectories (DPM analysis, erosion analysis), the problem is transient so decided to take care with the courant number so i use a size of time step of 3e-6 and 1.5 e-6, i know the depency of the mesh with the courant number and the velocity (17 m/s in this case) so i try to put a "bed" to avoid the effect of the reverse flow at the outlet, also i use a good size in the wall to evaluate the boundary layer Y+ (i used a typical equations based on the Reynolds numer), i used pressure outlet or outflow boundary but in the two cases "reverse flow" appear (also the relation H/D is too short, 1 in this case) i hope a core of the jet not a developed region, the cuestion here is in what is the ralation in my result if i keep this reverse flow, the issue too is that the convegence is still remain (i used a 1e-6 value for residuals).
Is true mantain this approach because anyways a reach a convergence (only residuals, not constant pressure at the wall)
Additionally i use a report plot to monotoring the pressure in the wall impingement but this mantain a occilatory behavior until around 0.004 seconds.
I let you two screen of the mesh and the fluent GUI [IMG][/IMG]
maurokillary13 is offline   Reply With Quote
courant number, jet impingment, reversed flow, transient 3d
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
OpenFOAM - Reverse flow occur while ozgunoglu OpenFOAM Running, Solving & CFD 1 February 6, 2017 07:21
Laminar Wall Jet Flow over a Shallow Cavity javadkz FLUENT 0 October 3, 2016 02:41
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 04:44
momentum & x-vel convergence, and reverse flow problem cinwendy FLUENT 0 April 17, 2013 02:19
