June 10, 2021, 02:14 |
Difference in Pressure value at outlet
Dhayananth
Rep Power: 11 |
I am applying pressure outlet boundary condition for my flow problem. The pressure value is constant = 13332.2 Pa. Its a transient problem, so I ran the simulation for 1 time step. Then calculate the pressure value at the outlet. Now it changed to 13234 Pa. What is the reason for difference in pressure value? |
June 10, 2021, 06:04 |
Rep Power: 26 |
Maybe you specify total pressure, and calculate static pressure...
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Question Concerning Pressure Value (Pressure outlet) and Reference Pressure (Physics) | andy_flow | STAR-CCM+ | 1 | July 9, 2013 08:44 |
Using pressure outlet BC | Shreyansh | FLUENT | 0 | November 5, 2010 14:57 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
