How to run on multiple CPUs Fluent on a Cluster? |
June 18, 2021, 09:45 |
Rep Power: 9 |
I want to run simulations on a cluster with fluent. I can send my simulations to the cluster but it runs on only one cpu, even if it is allocating 108 cpus. Since I am using an intermediary software to send the simulations to the cluster, i do not know how to manipulate the command line directly, which starts the simulation. In a way i am trying to enable the section "-t108" in the command line. Is there a way to specify the parallelization options with the journal file? I want to select the option "Distributed Memory on a Cluster" instead of "Shared Memory on a Local Machine". A way to specify the paralelization while reading the case file maybe. Thanks for any help! |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Scripts to run fluent in Linux cluster via windows | sanjaykummar2810 | FLUENT | 1 | September 19, 2018 16:23 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
resume and run fluent for another timestep via a c | greg | FLUENT | 2 | June 30, 2005 05:01 |
