ANSYS 2020R2 MSMD NTGK battery model, UDS diffusivity problem |
June 20, 2021, 02:22 |
JAEYEOP KIM
Hello!
I have significant problem about my CFD simulation. I have did a tutorial about msmd, ntgk battery model. but i can't find the UDS diffusivity at material-solid dialog box. For a long time, I tried many times for the uds but it doesn't had a effect. below things are my option. please see the images, and give me some advices. and could you explain the meaning of UDS diffusivity? I don't understand what it is even now... thank you |
June 20, 2021, 21:12 |
Alexander
Rep Power: 34 |
open MSMD dialog box, go through all tab, press INIT, APPLY, OK
now go to material properties (your picture 5). there you would have UDS diffusivity
best regards ****************************** press LIKE if this message was helpful |
September 25, 2021, 16:10 |
#3 | |
Parvaneh Zare
Rep Power: 4 |
The problem has not been solved with the solution provided. Could you please let me know what the reason could be? |
September 26, 2021, 19:38 |
Alexander
Rep Power: 34 |
if you don't have uds diffusivity in material properties list it means MSMD was not loaded correctly
or it was not turned ON ( to turn it on press init apply inside msmd window)
December 4, 2023, 18:11 |
Hossein Darvish
I think the problem comes from using different versions. Under the last line in Create/Edite Materials dialogue box, Electrical Conductivity, you may choose defined-per-uds and then, in the UDS Diffusion Coefficient dialogue box that appears, you may be able to modify the Electrical Conductivity. Please see the following tutorial: https://ansyshelp.ansys.com/account/...rial_cell.html |
ansys 2020, fluent, msmd battery, uds diffusivity |
Evaporation model in ansys Fluent 12.1 | oldisbest | Fluent UDF and Scheme Programming | 12 | March 26, 2020 09:11 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
ANSYS Fluent: ECM Battery Model (video) | tom96 | FLUENT | 3 | October 12, 2018 08:43 |
uds diffusivity | Lee 小亢 | Fluent UDF and Scheme Programming | 4 | March 7, 2018 06:28 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 22:04 |
