September 2, 2021, 16:46 |
Negative nut occurring intermittently
Adithya
Rep Power: 4 |
Hello
I am simulating an aircraft with the SA model. Turbulent settings as per recommendations by Spalart and Rumsey. Coupled scheme with time factor 0.1 . All second order spatial discretization. In my mesh, i know that i have a few (<300 cells in a total of 85million) highly skewed elements. I also have very low orthogonality in some cells at different location. In the first 5 or so iterations, i get a warning message that a negative nut was calculated. It then disappears till around iteration 700. After that it reappears intermittently with a warning in around 1 to 7 cells. My x,y,z,energy, and nut residuals decrease steadily. My continuity however oscillates but also decreasing. Is this occurrence at a higher number of iteration something to be worried about? Can the solution diverge at this stage? If so, how do i correct it? |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
