Fluent intrinsic structural FSI solver
Old   September 6, 2021, 19:42
Default Fluent intrinsic structural FSI solver
Marcin
destroy is on a distinguished road
Dear all,
I am using the fluid-structure interaction (FSI) approach with coupling of Mechanical and Fluent. It is working by transferring data (integrated pressure, displacements etc.) between solvers by multiple so-called coupling iterations.
Recently I discovered, that Fluent itself has an option to use build-in simple structural solver to facilitate FSI simulation. I will use this approach and compare the results with the standard approach described above. However, I do not understand, and I did not found the information in theory guide, on how the intrinsic FSI solver works. I mean, are there any coupling iterations? Or there is created a monolithic matrix, as in monolithic solvers such as Abaqus?
Kind regards
Destroy
destroy is offline   Reply With Quote
Old   June 13, 2022, 22:30
lzhaok6 is on a distinguished road
Intrinsic FSI in FLUENT still use a partitioned scheme, solving fluid by CFD and solid by FEM. However, there is a few limitations such as thermal expansion is not captured and the structure Young's modulus has to be constant, which I don't understand why.
lzhaok6 is offline   Reply With Quote
Dynamic FSI with SU2 Compressible Solver and SU2 FEM Solver Diverges when restarted sangeet SU2 7 August 3, 2022 02:54
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Compressible Solver Implementation in FSI Library (Foam-extend 3.2) KarthickRajkumar OpenFOAM Programming & Development 1 January 4, 2017 07:45
FSI Structural convergence problem Blizzard99 CFX 13 December 23, 2014 04:45
couple OF with ext. structural solver: how to interpolate BC matteoL OpenFOAM 0 July 29, 2010 09:30
