Rep Power: 8 ![]() |
Hello!
I'm currently trying to implement a Fluent case with a specified slip velocity. However, the boundary condition only allows me to use the no-slip condition or to specify a shear stress with the corresponding vector components. I then thought, I could calculate the vector components to result in a constant slip velocity, but this doesn't seem to work with my current understanding of the stress tensor. When I look into the Ansys manual (https://www.afs.enea.it/project/nept.../th/node11.htm), the stress tensor is a result of the viscosity and some kind of velocity derivatives. But exactly the latter one need to be zero (in my understanding) to result in a constant slip velocity... What should I therefore enter in the shear stress components? Or is this a completely bad route I'm trying to take? I am grateful for any information you could provide me, to better understand this topic. Thank you! For anyone wondering, I need to implement an "apparent" slip-condition, as already reported for polymer solutions in literature. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
If you're trying to impose the velocity at a boundary, use a velocity inlet. Or you can even use a no slip moving wall.
Javid
Rep Power: 0 ![]() |
Hey Jonas,
I was wondering if you could sort it out? |
Emmanuel Quayson-Sackey
Hello Jonas,
I am also facing the same problem . Can you please share with us if you found solution to that. |
Slip boundary condition in OpenFOAM | chitransh_atre | OpenFOAM Pre-Processing | 0 | June 14, 2020 22:14 |
comsol: use general slip condition on the external slip wall | sobhan.f | COMSOL | 0 | April 30, 2015 06:16 |
having trouble implementing airfoil with Wall Slip condition | Khozaei4000 | FLUENT | 1 | December 22, 2014 12:30 |
having trouble implementing airfoil with Wall Slip condition | Khozaei4000 | CFX | 10 | December 22, 2014 06:21 |
Partial slip Johnson-Jackson wall boundary condition OF 2.3.0 | mwaqas | OpenFOAM Running, Solving & CFD | 5 | December 4, 2014 18:44 |
