TUI command to access reaction arrhenuis rate |
September 19, 2021, 10:27 |
Brad
Rep Power: 5 |
Hi
I would like to know the TUI commands top access a mixtures reaction arrhenuis rates. I am modelling a pulverisied coal power plant, and need to run the simulation on a computing cluster, thus a TUI journal file is required. I am running a parametric study thus need to change the arrhenuis rate from the default for each run. I can access the materials Reaction section using the following code: /define/materials> change-create material-name> coal-volatiles-air material name [coal-volatiles-air] coal-volatiles-air is a mixture change Mixture Species? [no] change Reaction? [no] yes Reaction method is finite-rate/eddy-dissipation number of reactions [2] reaction name: reaction-1 ["reaction-1"] reaction-1 surface reaction? [no] particle surface reaction? [no] electrochemical surface reaction? [no] specify 3rd body efficiencies? [no] number of reactants [2] available species: (vol o2 co2 h2o co so2 n2) reactant-1 [vol] stoich coeff of vol [1] rate exponent of vol [0.2] available species: (vol o2 co2 h2o co so2 n2) reactant-2 [o2] stoich coeff of o2 [1.033506260368654] rate exponent of o2 [1.3] number of products [4] available species: (vol o2 co2 h2o co so2 n2) product-1 [co] stoich coeff of co [1.002010447481314] rate exponent of co [0] available species: (vol o2 co2 h2o co so2 n2) product-2 [h2o] stoich coeff of h2o [1.757696823475719] rate exponent of h2o [0] available species: (vol o2 co2 h2o co so2 n2) product-3 [n2] stoich coeff of n2 [0.05530562227250216] rate exponent of n2 [0] available species: (vol o2 co2 h2o co so2 n2) product-4 [so2] stoich coeff of so2 [0.04669296337005573] rate exponent of so2 [0] reaction-1 Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: () But I get the above error, when the next part should be the arrhenuis rate expression inputs. Any help as to how to access this will be greatly appreciated. Regards |
September 22, 2021, 23:35 |
Alexander
Rep Power: 34 |
shouldn't it be
"reaction-1" Code:
reaction-1
best regards ****************************** press LIKE if this message was helpful |
arrhenuis rate, tui command |
Negative reaction rate | lilistar-8216 | FLUENT | 1 | April 24, 2020 08:24 |
[help!] Empirical Reaction Rate UDF | cinwendy | Fluent UDF and Scheme Programming | 8 | June 14, 2017 07:16 |
UDF for volumetric reaction rate | Boniface Omar | Fluent UDF and Scheme Programming | 0 | July 25, 2016 02:39 |
reaction rate | Benfa | CFX | 0 | January 22, 2013 13:58 |
Dissipation rate access | K. Kevala | FLUENT | 0 | July 14, 2004 11:11 |
