November 8, 2021, 02:43 |
Turbulent heat flux
Wojciech Gołda
Rep Power: 5 |
Hello everyone!
Could someone help me how to calculate turbulent heat flux in my case? For example plot turbulent heat flux on some wall? I know in post cfd there is no output like "turbulent heat flux", so what value I have to have to calculate it. Could anybody help me how to do it? Best regards, WG |
November 8, 2021, 03:25 |
Lucky
Rep Power: 66 |
Are you sure that's what you want to do?
At walls you have no slip and no turbulent fluctuations. The turbulent heat flux is zero. |
November 8, 2021, 03:29 |
Wojciech Gołda
Rep Power: 5 |
Hello LuckyTran, maybe you are right. I am bit beginner in CFD world. So could I calculate turbulent heat flux in whole domain? Or for example in straight line of flow? If yes, how to do that?
Thank you for your reply. |
November 8, 2021, 05:15 |
Lorenzo Galieti
Rep Power: 12 |
I am not sure, the no slip condition is applied at the cell face, not at the cell center, where the velocity is actually going to be non zero. When Fluent calculates the heat flux through the wall, it uses cell centered values to reconstruct the gradient, so the conductivity is going to have a turbulent contribution.
November 8, 2021, 09:20 |
#5 | |
Lucky
Rep Power: 66 |
To get the turbulent heat flux field (which is a vector field) you need to fetch the temperature gradient then multiply it by the turbulent viscosity and divide by the turbulent Prandtl number. Depending on your definition of turbulent heat flux (you may/may not need to divide also by the density). You can create custom field functions or a UDF. If done using a custom field function, the temperature gradients aren't available by default. You must enable the option to retain them in memory during calculation. There are three components of the temperature gradient dT/dx, dT/dy, and dT/dz so you will need 3 custom fields. Here's a cute YT video on how to retain the temporary storage and includes the temporary gradient as an example. |
November 8, 2021, 12:45 |
Wojciech Gołda
Rep Power: 5 |
Hello LuckyTran,
I got ma dT/dx and dT/dy. I also got turbulent Prandtl Number and Turbulent Viscosity. So if I have dwo gradients, dT/dx and dT/dy which gradient should I calculate? |
November 8, 2021, 13:28 |
Lucky
Rep Power: 66 |
Both. Or whatever you need. Each is a component of the turbulent heat flux. Remember, heat flux is a vector.
Anisotropic turbulent heat flux. | Golaselo | Main CFD Forum | 2 | June 28, 2022 05:29 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Turbulent Heat Flux Question | deji | OpenFOAM | 5 | August 1, 2016 09:27 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
