Discussion: How to use Fluent calcuating aircraft dynamic derivatives in steady runs?
Old   November 23, 2021, 05:08
Default Discussion: How to use Fluent calcuating aircraft dynamic derivatives in steady runs?
Sheng
micro11sl is on a distinguished road
Hi all,
I have been using Fluent for aircraft aerodynamics modelling for some time. But recently I encountered a problem of simualting aircraft dynamic derivatives.
The question is simple, how to use Fluent calculating aricraft dynamic derivatives, especially in steady runs?
Let's say an aircraft in a loop maneuver, how will you guys perform the setup?
I've searched old threads, the existing posts provide no clear answers, e.g.,
unsteady rotation
Aircraft dynamic stability derivatives
and
Aerodynamic Stability Derivatives
Thanks in advance
Sheng
micro11sl is offline   Reply With Quote
Old   November 23, 2021, 05:12
Sheng
I notice a link here https://www.m4-engineering.com/dynam...ves-using-cfd/ , which is very related to this topic. The link suggests STARCCM and FUN3D. I suppose Fluent should be able to do the same thing. But I yet know how to perform same simulations as those described in the link.
parallel fluent runs being killed at partitioing Ben Aga FLUENT 3 June 8, 2012 10:40
Dynamic Mesh Can not Be Used in FLUENT 12.0 lzgwhy ANSYS 1 April 18, 2010 18:19
Moving Dynamic Mesh in Fluent 6.2 R.M.Bharath Somayaji FLUENT 0 January 9, 2006 20:36
Have starcd some technology like fluent dynamic me Kevin Siemens 7 October 25, 2005 13:08
Aircraft dynamic stability derivatives Jon FLUENT 3 October 1, 2004 01:57
