November 26, 2021, 03:01 |
fluent unsteady file injection
樊纯玉
Hi everyone,
I hope you are all well. I have a CFD question about my simulation. The software version I use is ansys2021r1.In the DPM model, it is allowed to use a file with the format of . inj as the initial injection, which is divided into steady state and unsteady state. The unsteady file injection format is: (z=4) (x y z u v w d t mf m n time flowtime name) However, in fluent calculation, only one line is read each time I use unsteady file injection, no matter how many lines I set.The following is displayed in the fluent console: NO TYP (X) (Y) (Z) (U) (V) (W) (T) (DIAM) (MPARCEL) 0 IN 0.00e+00 0.00e+00 5.50e-02 1.00e+00 0.00e+00 0.00e+00 4.00e+02 3.73e-05 1.00e-11 I want to know whether the ANSYS software can only read one line of data or my setting is wrong. Thanks,My English expression ability is limited. I hope you don't mind. |
November 26, 2021, 03:42 |
Alexander
Rep Power: 34 |
go to help
PART III: SOLUTION MODE | CHAPTER 20: MODELING DISCRETE PHASE | 20.3. SETTING INITIAL CONDITIONS FOR THE DISCRETE PHASE there is a detailed manual for instance you may try to change you (z=4) line to (z=4 13), as it is written in manual means the header has 13 parameters (which could be different) and name.
best regards ****************************** press LIKE if this message was helpful |
fluent dpm file injection |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
