December 12, 2021, 02:42 |
NTGK Parameter Estimation Tool
Rep Power: 7 |
Hi all,
I am trying to simulate a battery pack's thermal behaviour. I have obtained the battery voltage-time data, and am trying to give it to ansys as input via parameter estimation tool. However, it causes some problems. At some point in iterations, the voltage and temperature values are going through the roof. When I looked at the fitting-results, I saw the reason. And I have no idea how to solve it. Any help would be appreciated. I attached the data files and the image of the problematic values. Last edited by SplendidaVitia; December 12, 2021 at 03:58. |
December 13, 2021, 23:11 |
Alexander
Rep Power: 34 |
you may try to use default NTGK parameters to make sure your model is correct
as you know the moment of problem so you know SOC of the battery you may try to plot Y and U parameters vs SOC and check what is going on near problem SOC for more information about NTGK read ANSYS Fluent Advanced Add-On Modules -> NTGK Model temperature correction could be a problem also
best regards ****************************** press LIKE if this message was helpful |
March 3, 2023, 15:03 |
NTGK U and Y parameters
ahmet kaya
Rep Power: 5 |
Hello, how can I fit the U and Y parameters? I use ANSYS Parameter Estimation tool
March 6, 2023, 12:41 |
parameter fitting
ahmet kaya
Rep Power: 5 |
ı have the same problem and no ınformatın stılle ı have
November 14, 2023, 06:18 |
#5 | |
ntgk, parameter estimation tool |
[ANSYS Meshing] Workbench Meshing Tool - Max Face Size Parameter | MaxHeat | ANSYS Meshing & Geometry | 3 | March 2, 2021 07:50 |
[PyFoam] running pyFoam(Plot)Runner.py in parallel | Studi | OpenFOAM Community Contributions | 10 | September 6, 2015 16:38 |
[GAMBIT] What is the shape parameter in "Create Conic Arc" tool ? | minhquan | ANSYS Meshing & Geometry | 4 | November 21, 2012 07:00 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Y+ Estimation Tool | pete | Site News & Announcements | 1 | August 4, 2011 04:49 |
