Memory leak problem while running transient simulation |
January 13, 2022, 05:23 |
I'm new to Ansys Fluent and i'm currently facing a memory usage problem while running a transient simulation. At the beginning, the memory usage is ~30% and then it keeps increasing after each iteration until it reaches 100% and force Fluent to close. - Running on 2021R1 Ansys Fluent version (premium). - CPU is an Intel Core i5-7500 with 4 cores - 32GB DDR4 ram - ~400k cells geometry - Transient, k-epsilon turbulent, VOF, SIMPLE velocity-pressure coupling - 10,000 time steps with 0.001 time step size - No dynamic meshing - Data are autosaved every 0.1s of flow time. Is anyone facing same difficulties ? Best regards, Axel |
March 7, 2022, 04:52 |
wei l
hello,
i am facing the same problem, do you know how to solve it? regards, Wei |
Problem when running simulation | pak_sargon | CONVERGE | 4 | July 6, 2021 23:29 |
Transient Simulation in CFX | ashtonJ | CFX | 1 | September 28, 2018 01:18 |
Polyflow Simulation with ViscoElastic Model memory problem | sid2909 | FLUENT | 0 | May 10, 2010 05:29 |
Polyflow Simulation with ViscoElastic Model memory problem | sid2909 | ANSYS | 0 | May 10, 2010 05:27 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
