aun ali
Rep Power: 4 ![]() |
My simulation shows temp contours as in pic1. but it should be like pic2. please guide, what's the problem with my simulation?why heat transfer did't show in inner tube.
Alexander
Rep Power: 34 ![]() ![]() |
you should have coupled boundary condition on walls between zones.
It can be done: 1. automatically-> in design modeler both zones should be in one part. in that case shadow wall will be created automatically on the boundary between fluid and solid zone. 2. manually.-> in that case you have interfaces in your model. create interface between solid and fluid zone, define coupled boundary condition
best regards ****************************** press LIKE if this message was helpful |
aun ali
thanks Alexander. manually i defined interfaces and applied coupled wall in mesh interfaces. after that i got 4 walls ( top 4 mentioned in the pic). now the problem is that in which wall will i define heat flux ?. in my condition i applied flux in the shadow wall and a-wall-1-1.
Alexander
between zone 1 and zone 2 you may have interface or wall with shadows not both
in addition you may have heat flux boundary condition or coupled boundary condition
Conjugate Heat Transfer in rectangular pipe with cylindrical pins | PabloXX37 | System Analysis | 0 | November 20, 2019 09:46 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Pipe flow heat transfer | feedq | FLUENT | 10 | November 26, 2014 08:23 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
