Can ROM Builder be able to simulate/predict different geometric parameters? |
February 15, 2022, 03:55 |
Kaboka
Rep Power: 6 |
Hello everyone,
I am working on a Diffuser's CFD model which I would like to solve with different diffuser angles and inlet velocities. However, I cannot select the diffuser angle parameter, which I had defined in DesignModeller, in DoE of 3D-ROM. I would appreciate it if anyone has any ideas or links to examples. Bests |
February 16, 2022, 08:52 |
Lorenzo Galieti
Rep Power: 12 |
Hi kaboka,
Having back in the days tested the very early version of the ROM builder which was provided me by the developers, I can confirm you 100% that this is not possible. Different geometry = different Mesh, in particular, also different number of elements. What the ROM does is building a reduced order model (ROM) of the variables of interest for each mesh element, based on the value of such variables provided by the different solutions you use to train the model. In case the mesh changes, it is a bit weird In theory, it could be possible to obtain a ROM in a part of the domain which is not changing, provided you also, somehow, manage to obtain the same mesh there, but I do not believe it is something possible with the current release version. |
February 16, 2022, 09:18 |
Kaboka
Rep Power: 6 |
Hi Lorenzo,
Thanks a lot for your answer. Now it's more clear that it's not quite possible. As I found a developer, one more question that's in my mind is the reduced-order model of transient 3D CFD simulations in ANSYS Workbench. I can easily generate a ROM model of a 3D-CFD steady-state simulation but for transient, I heard that's a bit hard in ANSYS, or do I need to buy the Twin Builder Licence for the Dynamic ROM Builder? If you had any roadmaps, that would help a lot. Bests |
February 16, 2022, 12:02 |
Lorenzo Galieti
Rep Power: 12 |
Bear in mind, I was no developer, I just happened to test a very early version for my company. We where interested in using it for combustion applications.
Back in the days it was only possible to generate Roms for steady simulations. I am not sure if then they added the possibility to do it for unsteady runs. For time averaged flow fields of unsteady runs, it should be easy to generate Roms..... If you want instead "time resolved" Roms, I am not sure. |
Solver parameters to solve convergence issue | WilliamH | SU2 | 5 | February 5, 2021 06:19 |
Parameters of a good airfoil mesh | CharlieBra7o | Mesh Generation & Pre-Processing | 4 | November 20, 2018 14:42 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
Parameters for multigrid solver | HaZe | OpenFOAM Running, Solving & CFD | 3 | January 28, 2012 02:05 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
