huge values of velocity and force for hydrofoil
Old   March 5, 2022, 16:41
Default huge values of velocity and force for hydrofoil
mohammad
mmd96 is on a distinguished road
Hi
I'm trying to simulate a floating hydrofoil in water by 6DOF solver in fluent (time transient). hydrofoil is NACA 0012 and chord length is 1m and span length is 1.5m. I insert the hydrofoil in the center of a cubic domain. Velocity inlet is 1m/s and gravity is -9.81 m/s2.
The hydrofoil mass is 216kg and I calculate moment of inertia. I set these properties in 6dof properties.
The velocity and force of hydrofoil increase every time step when the values are so huge fluent give "floating point exception" error.
When I change fluid from water to air it seems ok.
The force of the hydrofoil and mesh is shown below.
Thanks
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
mmd96 is offline   Reply With Quote
6dof; hydrofoil;
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 13:38
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 04:47
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 11:25
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 08:56
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 04:50
