Compressible Fluid - Floating point exception - solution diverging
Old   March 5, 2022, 18:13
Default Compressible Fluid - Floating point exception - solution diverging
Marcin
destroy is on a distinguished road
Im performing FSI simulation (Fluent+Mechanical+System Coupling) and I tried to use a compressible density model for Water - to check whether it helps with stabilizing solution. However, I am getting a diverged solution. This does not happen when I use a constant density. I am using the same settings as default. I also tried to use a Density Exponent equal 1.0 - with the same unsuccesfull result.
My settings are in attached image. In Fluent I am using an operating pressure (Physics->operating conditions) equal 101325 Pa, and Referrence pressure (set in Refference values) equal 0 Pa.
What I am doing wrong?
Regards
destroy is offline   Reply With Quote
rhoSimpleFoam floating point exception RuffiE44 OpenFOAM Running, Solving & CFD 1 May 20, 2020 17:50
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 11:43
compressible DEM floating point exception motzi OpenFOAM Programming & Development 0 March 1, 2012 11:00
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
