Node 0: Process 20804: Received signal SIGSEGV.
Old   March 16, 2022, 20:16
Exclamation Node 0: Process 20804: Received signal SIGSEGV.
Khoa
luonghuynhdangkhoa1998 is on a distinguished road
Hello Everyone,
I'm a newbie in FLUENT with UDF.
My case is to run an initial Mesh for MobyDick Nozzle for the base research with our UDF function of our team's new Thermal Phase Change Model. I have try to run without the UDF, and everything is OK, as a result.
However, when trying to use UDF function, I got this error: "Node 0: Process 20804: Received signal SIGSEGV."
I have interpreted the UDF file successfully and set the number of User-Defined Memory Locations to 3 and the number of User-Defined Node Memory Locations as 0.
My UDF in detail:
/* UDF to define a simple mass transfer based on Saturation Temperature. The "from" phase is the liqid and the "to" phase is the gas phase */
#include "udf.h"
#define c_evap 0.02
#define c_con 0.
#define p_sat 462300 /*Pa*/
#define T_sat 422.05 /*K*/
#define cigma 0.048933 /*N.m-1*/
#define acc_COEFF 1.2 /*accommodation coefficient*/
#define M 18.0152 /*Molecular weight*/
#define R 8314.34 /*Universal gas constant R (J/kmol-1.K)*/
#define PI 3.1416
#define Nb 4e+8 /*Bubble Number Density*/
DEFINE_MASS_TRANSFER(liq_gas_source,cell,thread,fr om_index,from_species_index, to_index, to_species_index)
real m_lg;
real m_cav;
real m_boil;
real dp;
real Area_Den;
real p_vapor;
real dp_liq, dp_gas, dp0, source_evap, source_con;
Thread *liq = THREAD_SUB_THREAD(thread, from_index);
Thread *gas = THREAD_SUB_THREAD(thread, to_index);
m_lg = 0.0;
m_cav= 0.0;
m_boil= 0.0;
p_vapor = 0.0;
Area_Den=0.0;
dp = 0.0;
Area_Den = pow(6*C_VOF(cell,gas),2.0/3.0)*pow(PI*Nb,1.0/3.0);
p_vapor = p_sat + MIN(0.195*C_R(cell,thread)*C_K(cell,thread), 5.0*p_vapor);
dp = p_vapor - MAX(0.1,C_P(cell,thread));
dp0=MIN(0.195*C_R(cell,thread)*C_K(cell,thread), 5.0*p_vapor) + MIN(p_vapor-C_P(cell,gas),75.0);
if(dp > 0.0)
m_boil = acc_COEFF*Area_Den*sqrt(M/(2.0*PI*R*T_sat))*dp0;
m_lg=m_cav+m_boil;
return (m_lg);
luonghuynhdangkhoa1998 is offline   Reply With Quote
fluent, sigsegv, udf
parallel run in foam extend CRI_CFD OpenFOAM CC Toolkits for Fluid-Structure Interaction 5 March 28, 2024 08:36
How do I change the serial udf to parallel? dhdh89 Fluent UDF and Scheme Programming 14 June 4, 2020 09:04
Process 10300: Received signal SIGSEGV metaliat93 FLUENT 2 January 28, 2020 00:53
Foam::error::printStack(Foam::Ostream&) with pimpleFoam of OF1612 on Cluster shang OpenFOAM Running, Solving & CFD 7 January 24, 2018 08:30
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
