March 22, 2022, 13:17 |
drag coeifficient
Rep Power: 13 |
hi , could you explain to me how fluent calculates the drag coefficient because I find it negative and it is wrong.
thank you. |
March 26, 2022, 06:11 |
Adam
Rep Power: 4 |
It uses the reference values section in the Fluent Setup to calculate these values, perhaps you have set this up wrong. What is the problem?
March 26, 2022, 12:05 |
Rep Power: 13 |
hi, I find a negative cd .
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
Finding Drag Force from Skin Friction | Rob Wilk | Main CFD Forum | 0 | May 8, 2020 06:04 |
Induced drag, pressure drag, viscous drag. | aleix.de.toro | FLUENT | 2 | August 24, 2015 18:00 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
