Y+ range for different turbulence models and wall functions
Like Tree2Likes
  • 1 Post By Indra
  • 1 Post By xisluke
Old   April 26, 2022, 03:40
Question Y+ range for different turbulence models and wall functions
amin
amind is on a distinguished road
Hello everyone
I read somewhere that the Y+ range for different turbulence models is as follows:
Spalart Almaras : Y+~1
k-ω : Y+<1
K-ε/standard wall function : 30<Y+<300
K-ε/scalable wall function : Y+>11
K-ε/Non equilibrium wall function : 30<Y+<300
K-ε/Enhance wall treatment : Y+<5
* Is the above correct?
* Can anyone suggest a valid reference for Y+ ranges?
Unfortunately, there is no exact reference for Y + and in different books and websites, there are different explanations that are confusing.
Thanks in advance
amind is offline   Reply With Quote
Old   April 28, 2022, 06:56
Void_CFD-user
Indra is on a distinguished road
Originally Posted by amind View Post
Hello everyone
k-ω : Y+<1
Thanks in advance
Fluent theory guide is useful for getting these numbers.
In Fluent, K-w,Spalart Almaras and Menter Lechner treatement are y+ insensitive. That dosen't mean using a good y+ won't give you a better solution. There's no strict definition for y+ range these days, depends on how accurate you wanna be. Also as far as I know, scalable wall function helps avoid getting bad results from standard wall funstion in case of grid refinement. Not sure if there's a recommended y+ for scalable. Feel free to correct me if I'm wrong.
amind likes this.
Indra is offline   Reply With Quote
Old   April 30, 2022, 03:06
amin
Thanks for your reply.
Old   May 5, 2022, 11:20
Luca
xisluke is on a distinguished road
Generally, when you are using models able to solve directly for the variables at the wall, y+ should be <= 1 or at least <5 (as far as I know, this is the y+ limit related to the viscous sublayer within the BL region). Instead, when you are adopting wall funtions, generally you need to maintain y+ within the logarithmic range, so 30 < y+ < 300 (I know it is true at least for standard and non-equilibrium).
I do not know if specific intervals exist for enhance or scalable wall functions; for more info, you can also try to have a look at the original scientific papers
amind likes this.
xisluke is offline   Reply With Quote
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Wall Functions & Turbulence Models Query [y plus ranges] TheMightySpartan FLUENT 4 August 18, 2018 02:48
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
