July 26, 2016, 06:08 |
No combustion using Finite Rate
Hi everyone,
I am modeling a methane gas burner. I managed to get the cold flow running with no issues, but when I try to add combustion there is no reaction. Because of this I decided to do a very simple model to try to get combustion running on that one before doing it in my main model. For the simple model I have a very simple geometry. It is essentially cylinder with three equal diameter sections. My aim to the start the combustion on the second section of the cylinder. My setup is as follows:
What I have done so far:
My problem is that no reaction occurs, the solution is the same as the one with cold flow (no temperature increase, no combustion species present). However if I change the inlet temperature to 1500K the reaction starts from the inlet. This makes me guess that my setup is working, but for some reason the patching is not. What am I doing wrong? Why the reaction is not starting by patching the mid-section of the cylinder? Any help will be greatly appreciated! Many thanks! Victor |
July 27, 2016, 10:51 |
Andrea
Rep Power: 16 |
Hi Victor,
are you trying to simulate a counterflow flame here? If yes make sure that the strain rate is not too high otherwise the flame will be estinguished. It would probably be easier to simulate a simple swirl or bluff-body burner in order for the flame to be stable. If your case is turbulent I would recommend you to follow the following steps (I am assuming that you are using the species transport model): - run a cold flow simulation - patch high temperature and product species within the domain (close to where you expect the flame to be ignited) -select the Eddy Dissipation model and solve it (the combustion should be ignited now) -switch to Finite Rate/Eddy Dissipation model if necessary Hope this is helpful Andrea |
May 28, 2022, 14:19 |
#3 | |
maziar gheshlaghi
Rep Power: 4 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Finite Rate doesnt burn, while Eddy Dissipation does. | frankven2ra | FLUENT | 0 | July 24, 2016 03:58 |
finite rate mutistep combustion | torn | Main CFD Forum | 2 | April 24, 2015 23:19 |
Coal Combustion - Devolatilization Rate Unit | Amanda | FLUENT | 3 | July 18, 2007 12:55 |
Premixed combustion -Laminar finite rate model | Shankar | FLUENT | 4 | March 17, 2004 15:32 |
