boiling bubble can not separate of the heated wall |
June 9, 2022, 08:31 |
hongmin
hell0 guys:
I am recently doing the work about simulating the nucleate pool boiling using fluent, but i meet a problem confusing me two months. my geometry is 3D. At first, the size is 9cm*9cm*9cm, the result is normal,the boiling bubble can depart from the heated wall ,but when i change my geometry to 900um*900um*900um, the boiling bubbles keeping in the heated wall, merging with other bubbles my boundary conditions ,bottom,set heated zone temperature 378.15K,above 373.15K. top is pressure-out no backflow. I used the vof model. i change the contact angle between vapor and wall to 180° to prevent the bubble sticking in the heated wall, but still no results. although i reduce the suface tension coefficient, seriously the very little coefficient can have some improvement,maybe the 1/100 of 0.072. i really need your help, any suggestions may be siginificient to me ,thank you. |
Stability of reactingTwoPhaseEulerFoam with wall boiling simulations | achref_rabhi | OpenFOAM Running, Solving & CFD | 1 | November 21, 2019 18:44 |
3D simulation of bubble boiling in paraview | Fahmida | OpenFOAM Post-Processing | 2 | July 25, 2019 04:46 |
Multiphase wall boiling model | omaralyahia | CFX | 4 | July 14, 2015 21:41 |
Multiphase simulation of bubble rising | Niru | CFX | 5 | November 25, 2014 13:57 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
