Flow generated by fan/blower - bcs
Like Tree1Likes
  • 1 Post By LuckyTran
Old   June 10, 2022, 05:26
Default Flow generated by fan/blower - bcs
FireN is on a distinguished road
Hello
I have task to simulate and compare three different geometries of duct supplying air to fan(from one bottleneck to merely free from obstacles) and i have question about determining boundary conditions in this case. I would like the flow to be induced by fan rotation (steady state with reference frame).
In this case air is taken from ambient air and is released to ambient air. How should I set up BCs at the inlet and outlet? Should they be pressure inlet and pressure outlet with gauge pressure 0?
I would like to know hom much air can the fan move when at constant RPM in three cases.
thanks in advance for your replies
FireN is offline   Reply With Quote
Old   June 10, 2022, 09:24
Lucky
Yes. Use a stagnation / total pressure inlet and pressure outlet. Set the inlet total pressure to ambient (0 gauge pressure) and outlet static pressure to ambient (0 gauge pressure). Simulate it and then get then the flowrate from post-processing.
FireN likes this.
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
BC's for external flow (flow past a cylinder) halowine FLUENT 1 March 6, 2018 06:00
pisoFoam, fully developed pipe flow using cyclic BC's thijs1909 OpenFOAM Running, Solving & CFD 17 February 21, 2018 22:07
How to calculate k-epsilon ?, the flow is generated by difference of pressure. polo2k4 OpenFOAM 0 March 3, 2017 11:04
mass flow and pressure BC known at inlet, outlet BCs unknown akashmpatil FLUENT 1 December 12, 2013 13:02
