Is it reasonable for the calculation velocity of Fluent decreases with the increase o |
June 13, 2022, 09:32 |
Rep Power: 9 |
Is it reasonable for the calculation velocity of Fluent decreases with the increase of cpu cores, especially when the core number grows to a degree?
June 13, 2022, 10:29 |
Alex
Rep Power: 46 |
I interpret your issue as "running a simulation on N+1 cores takes longer than on N cores"
Correct? That's normal. How large N is when this first occurs depends on a lot of factors. One of the largest contributors is "parallel overhead". Running a simulation in parallel usually incurs a small amount of extra work that needs to be done, which isn't necessary for serial computations. This overhead can grow with N, leading to negative scaling at some point. |
June 13, 2022, 22:14 |
#3 | |
Rep Power: 9 |
June 13, 2022, 22:19 |
Could you tell me what is the parallel overhead? How can know which core number is su
#4 | |
Rep Power: 9 |
June 14, 2022, 03:27 |
#5 | ||
Alex
Rep Power: 46 |
What exactly that is depends on the implementation. Quote:
That's why it is hard to tell how many cores are ideal beforehand. Cell count often plays a role, but there are just too many other factors involved, even including the hardware used to run the simulation. It's trial&error before slowly building up experience with your particular simulations and hardware setup. |
June 14, 2022, 21:54 |
Thank you, if we have a same computer hardware, does the linux system have faster vel
#6 | |
Rep Power: 9 |
Thank you, if we have a same computer hardware, does the linux system have faster velocity than the windows system? What is the difference between them? Another question is there any difference of calculation velocity between the Brand machine and assembly machine? |
kindly help me .. i have and error at line number 147.. | m zubair | Fluent UDF and Scheme Programming | 0 | February 10, 2019 11:25 |
Fluent do not use my velocity field(by UDF) to solve energy equation | tangleiplus | Fluent UDF and Scheme Programming | 6 | January 21, 2019 21:28 |
UDF inlet velocity profile mismatch with Fluent | ChristineL | Fluent UDF and Scheme Programming | 15 | November 25, 2016 06:45 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
