Gas-solid fluid - FLUENT
Old   June 14, 2022, 20:38
Default Gas-solid fluid - FLUENT
Lube23
Lube23 is on a distinguished road
I am trying to simulate a GAS-solid fluid in an Eulerian-Lagrangian framework, only using FLUENT.
There is about one pipe which a derivation (SEE IMAGE):
For one side, the air is introduced, and for the derivation, the particles are presented. In the outlet, there is a mixture between air and gas.
However, I am not sure if it is correct to introduce the particles with the injection option? (Discrete phase>Injections)
Or should I'd work with the Multiphase option?
Thanks.
Lube23 is offline   Reply With Quote
Can we use fluent to simulate heat transfer in a solid body?(without fluid) Roh FLUENT 8 January 23, 2019 23:49
Solid and Fluid Domains in Fluent pvtschultz FLUENT 0 December 18, 2014 09:06
error message cuteapathy CFX 14 March 20, 2012 06:45
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
How Fluent distinguish between gas & liquid fluid? Jiri Novak FLUENT 2 March 17, 2006 06:27
