How to use other pc to run fluent in parallel mode?
Like Tree1Likes
  • 1 Post By zaynah04
Old   August 31, 2012, 02:38
Exclamation How to use other pc to run fluent in parallel mode?
Johnson Emmanuel
johnfriend is on a distinguished road
Hi, I have two pc containg 4 processor each. i want to use all 8 processor to run a computation in Fluent. how to do that?
johnfriend is offline   Reply With Quote
Old   August 31, 2012, 15:40
Jared Brewer
Jinglz is on a distinguished road
Submit a service request to ANSYS. They will take over and set it up for you in <10 mins. I struggled for a week trying to get a couple hexcore computers and a 16 core server to work together. There are some technicalities in the naming conventions and head node dedication that are not apparent in the documents they give you.
Jinglz is offline   Reply With Quote
Old   September 5, 2012, 04:55
zaynah K.
zaynah04 is on a distinguished road
i had started to study parallel processing in my spare time
it helps in running fluent in multiple PC
Sutheesh P M likes this.
zaynah04 is offline   Reply With Quote
Old   July 19, 2022, 12:17
Sutheesh P M
Sutheesh P M is on a distinguished road
can you explain the steps
Sutheesh P M is offline   Reply With Quote
fluent - udf - parallel, parallel computation, parallel computing
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 19:44
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 14:43
