August 13, 2022, 15:54 |
Drag Force Calculation
Pratik More
Hii i am trying to find the drag force on savonius turbine using 2d transient system. As the turbine is rotating constantly and the projected area is changing what should I put in reference values of area?
August 23, 2022, 00:33 |
jawahar sivabharathy
Rep Power: 15 |
Hi Pratik,
The drag force acting on the turbine changes with rotation. If you are using varying projected area you can't compare the coefficient with time. I would suggest you to use planform area to non-dimensionalize the drag force for understanding the dynamics. Thanks. |
fluent, savonius rotor, transient 2d |
Reynolds number for Sphere Drag Force calculation | abhishek_kgp | OpenFOAM Running, Solving & CFD | 1 | April 25, 2022 09:38 |
[OpenFOAM] Drag Force Calculation For A Porous Cylinder | Ishmael | ParaView | 0 | August 1, 2020 14:28 |
Applying drag force in the fluid model | CanadaFlanker | CFX | 7 | May 5, 2014 23:13 |
Lift force and Drag force calculation | KTJ | STAR-CCM+ | 3 | April 29, 2014 08:38 |
formula used for drag force? | kamma | Main CFD Forum | 0 | April 2, 2010 10:21 |
