[Sponsors] | |||||
HOJUN YU
Rep Power: 7 ![]() |
hi all.
I'm using a hexahedral volume, dT = 0.000016667s, each time step 0.1 deg rotation All faces adjacent to the rotation domain are interfaces. I'm trying to analyze a coaxial inverting propeller, but I'm having a bit of a problem. The domain proceeds as front blade volume > stationary volume > rear blade volume, and the front and rear rotate at the same speed and in different directions. Problem 1. There seems to be a mesh regeneration error when two forward and backward rotation domains rotate over time, so a negative volume is created and the calculation does not proceed what i did 1. Check the geometry 2. Check the volume 3. Check boundary conditions ( Cell > MeshMotion , Interface Periodic Rotation , Rotate on Walls Created by the Interface ) 4. Dynamic mesh What else can I do? Oh, by the way, the side of the front blade and the rear blade is the square Mesh |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
| Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
| ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
| Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
| DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
