September 23, 2022, 00:04 |
Unit in inlet & report definitions
Joko
Rep Power: 3 |
Hi guys, i try to run simulation of my pelton turbine. It's been 8 months since i start this research, create a geometry in ACAD, learn ansys, run the simulastion, etc. it would be very helpfull if you guys can help me so i can finish my college already.
First, i want to input inlet volumetric flow around 1.6 m3/s to run my pelton turbin simulation. Why the unit in inlet velocity magnitude is "m/s"? Is it possible to convert "m3/s" to "m/s"? What should i do if you cant convert "m3s" to "m/s"? And second, why the unit in my omega is "Hz"? I get my omega from vel max (facet maximum) then create new expression by using formula vel max/r[m]. When i try to run, the unit in omega plot becomes "Hz". I know you can convert "Hz" to "Rad/s" but still, if i can get my unit correctly in the plot, i wouldnt bother to make another graphic in in excel. Thanks. |
fluent, omega, units, velocity magnitude |
Problem with velocity inlet using FireFoam | Jean_S | OpenFOAM | 0 | July 5, 2021 04:40 |
Creating a Report Definitions Surface Plane | Ben_Hmouda | Main CFD Forum | 2 | March 15, 2021 12:18 |
K-Omega-Epsilon BCs for suction inlet | CFDBro | OpenFOAM Running, Solving & CFD | 0 | March 27, 2018 18:28 |
multiphaseInterfoam non-constant inlet | kaaja | OpenFOAM Running, Solving & CFD | 4 | February 23, 2018 02:04 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
