November 7, 2022, 10:59 |
Contour plotting algorithm
Rep Power: 6 |
Hello
In fluent (or CFD-post) what is the algorithm for interpolating the result across the entire surface? I know the simulation computes the variables at the nodes, however, what algorithm does the software use when plotting contours or extracting the information at any coordinate? Thank you |
November 10, 2022, 07:25 |
Alexander
Rep Power: 34 |
the reason why you need to get plotting algorithm is unclear
you may write all data into used defined node locations and plot by your own
best regards ****************************** press LIKE if this message was helpful |
[OpenFOAM] Plotting contour length over time steps | Rotidpor | ParaView | 0 | August 4, 2022 08:11 |
[OpenFOAM] plotting bubble shape from contour coordinates in matlab | JM27 | ParaView | 0 | May 15, 2020 15:30 |
Plotting pressure difference contour at a surface | pszatk | CFX | 1 | April 26, 2017 18:38 |
Plotting a contour of the turbulence production term in CFX-Post | kellio9 | CFX | 4 | March 19, 2013 11:34 |
Contour plotting | Mark Russell | Main CFD Forum | 5 | April 22, 2000 22:45 |
