Problem with hybrid initialisation
Old   November 7, 2022, 19:06
Question Problem with hybrid initialisation
tes
Ekaterina
tes is on a distinguished road
Hi! I need help to solve the problem when calculating the cooling of the flame tube.
I see this warning:
Checking case topology...
-this case has inlets & outlets both
-pressure information is not available at the boundaries,
so it will be initialized with constant pressure
Here's the detail i put while solving this question:
SOLVER TYPE : Pressure Based
Velocity Formulation : Absolute
Time : Steady
MODEL : k-w SST
BOUNDARY CONDITION :
1.
Inlet1: mass-flow-inlet (m = 0.001875, initial gauge pressure = 82500 Pa, T = 750 K);
Inlet2: mass-flow-inlet (m = 0.0075, initial gauge pressure = 80500 Pa, T = 1750 K).
2.
Outlet1: pressure-outlet ( Gauge pressure = 80000 Pa, T = 750)
Outlet2: pressure-outlet ( Gauge pressure = 80000 Pa, T = 1750)
Thank you!
tes is offline   Reply With Quote
Old   November 8, 2022, 21:20
HECKMANN Frédéric
fredo490 is on a distinguished road
Hybrid initialization is not a requirement and in many cases the standard initialization is recommended (see the manual for more details).
Hybrid initialization simply computes a quick Eulerian solution to try to give a more realistic flow pattern than a simple homogeneous initialization. It is only here to help convergence, it does not affect the final solution.
Simply ignore this message or switch to a standard initialization.
fredo490 is offline   Reply With Quote
ansys fluent, hybrid initialization, mass flow inlet, warning message
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
Convergence Problem in Multiphase problem (three phases) m.uzair FLUENT 0 August 2, 2018 08:23
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Hybrid Mesh and Zone surface problem Cadrian FLUENT 0 February 6, 2007 06:32
