Problem with reading a pdf transport file
Old   May 20, 2020, 15:39
Default Problem with reading a pdf transport file
Akram
Aero_Tn is on a distinguished road
Hi all
I have a problem with reading a pdf transport file
When I run the case file on ansys 19.1, and then I try to read pdf transport file (case.pdf), an error message appears saying that Version of the file (pdf file) : "fluent18.0" and fluent stops.
Can anyone help with that?
Thanks
Aero_Tn is offline   Reply With Quote
Old   May 20, 2020, 15:50
Default Pdf
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
PDFs have version compatibility but only if there are no structural changes. From 18 to 19, there might have been some changes to the format. Better to generate new PDF in 19.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 20, 2020, 15:58
Akram
The pdf table was created in a 19.3 version, but when I come back to log file, I find the the following :Version of the file: "fluent18.0"
I don't know from where 18.0 came
Old   May 21, 2020, 06:49
Default Pdf
vinerm's Avatar
Vinerm
The generation of the PDF does not write it. If there was an existing PDF file of same name, then, you will have to overwrite it. You can open PDF file in any text editor, such as, vi, gedit, or textpad and look for the details inside it.
Regards,
Vinerm
Old   April 28, 2021, 02:40
Default Non-premixed combustion-Fluent (Cluster)
papatel is on a distinguished road
Hi all,
I am using the Non-premixed combustion model for my case in the Transient step. Therefore, I have calculated a .pdf file for species. However, when I try to run it in the cluster, cluster won't able to read it. In fact, when I try to open this .pdf file on my local machine, it doesn't open.
Can someone please help me with this issue?
Kind Regards
papatel is offline   Reply With Quote
Old   December 13, 2022, 18:03
TX
monherry9 is on a distinguished road
Originally Posted by Aero_Tn View Post
Hi all
When I run the case file on ansys 19.1, and then I try to read pdf transport file (case.pdf), an error message appears saying that Version of the file (website to pdf file) : "fluent18.0" and fluent stops.
Thanks
The Version consistency for PDFs is possible, but only if there are no structural changes. The layout can be changed from 18 to 19. It is preferable to create a fresh PDF in 19.
monherry9 is offline   Reply With Quote
Old   December 15, 2022, 08:20
gugtenterf
gugtenterf is on a distinguished road
Originally Posted by papatel View Post
Hi all,
I am using the Non-premixed combustion model for my case in the Transient step. Therefore, I have calculated a .pdf file for species. However, when I try to run it in the cluster, cluster won't able to read it. In fact, when I try to open this .link to pdf file on my local machine, it doesn't open.
Kind Regards
Find the PDF you want to open in your Files and double click to open. Select Adobe Acrobat (or whichever reader you downloaded) from the list of available options. If no list appears or the page opens in another application, you can right-click the file and select Open With to choose your PDF reader. Click Open.
gugtenterf is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
