Periodic boundary conditions and meshing
Old   December 13, 2022, 13:44
Default Periodic boundary conditions and meshing
riesgar is on a distinguished road
I am simulating the flow over an array of cylinders. I would like the top part to have a periodic BC. I have seen that I need to do a match control in Ansys meshing so that the mesh is conformal. Is this compulsory? Which axis of rotation and high and low geometries should I select?
When I import my model into Fluent, I can make the top edges to be interfaces, but from there I cannot make them periodic as no option is enabled. Hope you can help me with this one.
Thank you
riesgar is offline   Reply With Quote
Old   December 13, 2022, 17:41
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you can't make periodic boundary with axis at the bottom
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 14, 2022, 16:58
What kind of BCs would you impose if you wanted to consider an infinite array of parallel cylinders with this geometry?
axis of rotation, match control, mesh 2d, periodic bc
Periodic boundary conditions using Fluent Meshing Alice_1994 FLUENT 0 November 21, 2022 09:24
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Translational Periodic Boundary Conditions HeatTransferFan CFX 19 December 12, 2016 11:15
Setting turbulent plane poiseuille model to periodic boundary conditions. QBeast FLUENT 0 July 17, 2011 10:08
periodic boundary conditions Satish Perivilli FLUENT 0 January 28, 2005 11:54
