December 13, 2022, 13:44 |
Periodic boundary conditions and meshing
Rep Power: 3 |
I am simulating the flow over an array of cylinders. I would like the top part to have a periodic BC. I have seen that I need to do a match control in Ansys meshing so that the mesh is conformal. Is this compulsory? Which axis of rotation and high and low geometries should I select? When I import my model into Fluent, I can make the top edges to be interfaces, but from there I cannot make them periodic as no option is enabled. Hope you can help me with this one. Thank you |
December 13, 2022, 17:41 |
Alexander
Rep Power: 34 |
you can't make periodic boundary with axis at the bottom
best regards ****************************** press LIKE if this message was helpful |
December 14, 2022, 16:58 |
Rep Power: 3 |
What kind of BCs would you impose if you wanted to consider an infinite array of parallel cylinders with this geometry?
axis of rotation, match control, mesh 2d, periodic bc |
Periodic boundary conditions using Fluent Meshing | Alice_1994 | FLUENT | 0 | November 21, 2022 09:24 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Translational Periodic Boundary Conditions | HeatTransferFan | CFX | 19 | December 12, 2016 11:15 |
Setting turbulent plane poiseuille model to periodic boundary conditions. | QBeast | FLUENT | 0 | July 17, 2011 10:08 |
periodic boundary conditions | Satish Perivilli | FLUENT | 0 | January 28, 2005 11:54 |
