Hello, everyone. I'd like to ask a question about the parallelization of DEFINE_GRID_
Old   March 27, 2023, 22:39
Thumbs up Hello, everyone. I'd like to ask a question about the parallelization of DEFINE_GRID_
rabbit-sun
rabbit_1 is on a distinguished road
#include "udf.h"
#include <stdio.h>
#include "dynamesh_tools.h"
static int thread_I=13;
#define NUM_USED_UDM 7
DEFINE_GRID_MOTION(cshadow, domain, dt, time, dtime)
#if !RP_HOST
Thread *tf = DT_THREAD(dt);
Thread *tf_shadow = THREAD_SHADOW(tf);
Thread *t2,*t0;
Node *v;
face_t face,f,f_shadow;
cell_t c2,cell,c0;
real tui,tui1,tui2,e1,midu,p;
real ee,ee1;
real area,wall_shear_force;
real ct0,ct1,x,reliu,wendu;
real NV_VEC(V), NV_VEC(A);
int n,i=0,j=0;
SET_DEFORMING_THREAD_FLAG (THREAD_T0 (tf)); // set deforming flag on adjacent cell zone
begin_f_loop(f, tf)
if(PRINCIPAL_FACE_P(f,tf))
f_shadow=F_SHADOW(f,tf); /*get the corresponding face in the shadow thread */
ct0=C_T(F_C0(f,tf),THREAD_T0(tf));
p=C_P(F_C0(f,tf),THREAD_T0(tf));
ct1=C_T(F_C0(f_shadow,tf_shadow),THREAD_T0(tf_shad ow));//固体侧温度
F_AREA(A,f,tf);
reliu=-1.0*BOUNDARY_HEAT_FLUX(f,tf)/NV_MAG(A);
f_node_loop(f, tf, n)
v=F_NODE(f, tf, n);
if(NODE_POS_NEED_UPDATE(v))
NODE_POS_UPDATED(v);
//异相化学反应:r=(A*T的0次方*e幂(-E/RT)Pj的0.5次方)/midu,j是氧化物组分co2和h20
//tui=1500*pow(2.718,-290000/8.314/ct1)*pow(p*F_YI(f,tf,0)/18,0.5)/2000+28.3*pow(2.718,-280000/8.314/ct1)*pow(p*F_YI(f,tf,1)/44,0.5)/2000;温度指的是壁温
if(C_YI(F_C0(f,tf),THREAD_T0(tf),2)>0.0&&time<=4) //C_YI(c,t,i):species mass fraction宏,此处表示有co(i=2)生成时,开始计算壁面退移速率
tui1=0.75*pow(2.718,(-34880.92/ct1))*pow((p*C_YI(F_C0(f,tf),THREAD_T0(tf),0)/18.0),0.5)+0.01415*pow(2.718,(-33678.133/ct1))*pow((p*C_YI(F_C0(f,tf),THREAD_T0(tf),1)/44.0),0.5);
if(NODE_X(v)>0.124) //本案例对机械侵蚀发生区域进行限制(忽略收敛段的机械侵蚀,只考虑扩张段机械侵蚀)
ee=1.0*NODE_Y(v);
ee1=-1.0*pow(1.0*27.3399/23.7052,2)+1000000*ee*ee/pow(1.0*23.7052,2);//计算截面膨胀比与喷吼出口膨胀比之差
tui2=1.5*pow(ee1,0.49)*pow(2.718,-1.0*ee1)*0.001;//机械侵蚀计算公式
tui=tui1+tui2;
NODE_Y(v)=NODE_Y(v)+(tui1+tui2)*dtime;
else
tui=0.0;
NODE_Y(v)=NODE_Y(v)+tui*dtime;
C_UDMI(F_C0(f,tf),THREAD_T0(tf),2)=reliu;
C_UDMI(F_C0(f,tf),THREAD_T0(tf),3)=ct1; //存储固体侧温度
C_UDMI(F_C0(f,tf),THREAD_T0(tf),4)=ct0-ct1; //存储流体和固体侧温度差
C_UDMI(F_C0(f,tf),THREAD_T0(tf),5)=tui*1000.0;
end_f_loop(f, tf)
#endif
DEFINE_GRID_MOTION(c, domain, dt, time, dtime) //加载在画网格时建立的wall上 固体
#if !RP_HOST
Thread *tf=Lookup_Thread(domain, thread_I); //thread_I获取流体侧线指针
Thread *tf_shadow = THREAD_SHADOW(tf); //然后把指针传给固体,控制固体侧节点移动
Thread *t2,*t0;
Node *v;
Node *v_shadow;
cell_t c2,cell,c0;
real A[ND_ND];
real tui,tui1,tui2,ct1,ct0,p,ee,ee1;
int n,i=0;
SET_DEFORMING_THREAD_FLAG (THREAD_T0 (tf_shadow));
begin_f_loop(f, tf)
f_node_loop(f_shadow, tf_shadow, n)
v_shadow = F_NODE (f_shadow,tf_shadow, n);
if(NODE_POS_NEED_UPDATE(v_shadow))
NODE_POS_UPDATED(v_shadow);
tui1=0.75*pow(2.718,(-34880.92/ct1))*sqrt(p*C_YI(F_C0(f,tf),THREAD_T0(tf),0)/18.0)+0.01415*pow(2.718,(-33678.133/ct1))*sqrt(p*C_YI(F_C0(f,tf),THREAD_T0(tf),1)/44.0);
if(NODE_X(v_shadow)>0.124) //本案例对机械侵蚀发生区域进行限制(忽略收敛段的机械侵蚀,只考虑扩张段机械侵蚀)
ee=1.0*NODE_Y(v_shadow);
ee1=-1.0*pow(27.3399/23.7052,2)+1000000*ee*ee/pow(23.7052,2);//计算截面膨胀比与喷吼出口膨胀比之差
NODE_Y(v_shadow)=NODE_Y(v_shadow)+(tui1+tui2)*dtim e;
else
tui=0.0;
NODE_Y(v_shadow)=NODE_Y(v_shadow)+tui*dtime;
end_f_loop(f, tf)
#endif
Can you help me see what's wrong with this udf parallelization? Thank you very much!
rabbit_1 is offline   Reply With Quote
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
