Dialogue box appearing when I change settings during solution in the fluent
Like Tree1Likes
  • 1 Post By vinerm
Old   March 25, 2020, 06:02
Smile Dialogue box appearing when I change settings during solution in the fluent
Mohamed Abdulazim
Mohamed Abdulazim is on a distinguished road
Hello everybody,
when I change some settings in the fluent during the solution such as turning off energy equation during the calculations, a dialogue box appears asking me whether I need to use setting changes for current calculations only or current and future calculations, I chose current and future calculations by default. Does that erase the previous calculations in energy equation or keep the results to be used in case of turning on the energy equation again. Frankly, I need to understand the difference between the two choices in the dialogue box. Thanks in advance.
Mohamed Abdulazim is offline   Reply With Quote
Old   March 25, 2020, 06:08
Default Option
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
This will not erase any data. It just asks if you want to keep the newly made changes in the settings for the future or only for this particular run. You chose the right option.
Mohamed Abdulazim likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 25, 2020, 06:25
Mohamed Abdulazim
Thank you very much, Vinerm.
Old   May 15, 2023, 07:47
Default save settings for future calculation not available
Basile
Basoule is on a distinguished road
I want to save change settings for current and future calculation.
However, the option is gray and I can't select it.
screenshot : https://ibb.co/xmcD2Cw
Before, I could select this option for my other case but I don't know why I can't for this one.
Could someone help me ?
Thanks
EDIT : it was a problem with the incoming mesh.
Basoule is offline   Reply With Quote
Update failed for the Solution component in Fluid Flow (Fluent). The Solution compon Faiz94 FLUENT 1 June 10, 2019 16:17
Settings for sliding mesh or MRF in Ansys FLUENT sgysin FLUENT 0 September 26, 2018 14:39
How to change boundary conditions by judging the temperature of one point in fluent? hotin87 Fluent UDF and Scheme Programming 16 September 25, 2015 03:01
solution convergence and mesh density in k-omega model (FLUENT) ripong FLUENT 0 January 29, 2015 17:09
Solution calculations and convergence in Fluent Freeman FLUENT 7 May 3, 2009 22:26
