Large mesh file leading to error "The fluent process could not be started" |
May 17, 2023, 11:22 |
Sebastien
Rep Power: 4 |
Hey guys,
I am facing quite a similar issue as this post, I try to initialize my case file and it is ok with a "medium" mesh (with hexahedron cells of 5 microns length, 3,960,000 cells, mesh file of 273,276 kb) but I got the same error than fluidizedbed when trying to use cells of 3 microns (18,300,000 cells, mesh file of 1,726,340 kb) My domain is 1.5 x 0.6 x 0.55 microns I tried going from 1 GPGPU to 0 as advised on the post I linked above but it did not help. Not sure I full understand the link shared by Kareem. Does anybody have an other solution to solve this issue ? FYI, I am using Fluent 2021R1 (but same issue with Fluent 2022 R2) on my Uni's HPC, Enterprise capability level, 3D, double precision set up [UPDATE] I've solved the issue, I was working connected to a node of our HPC but not using all of its memory. By increasing the memory usage, I've managed to initialize and run my job Last edited by sfawn; May 25, 2023 at 07:05. Reason: Solved |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 9, 2022 23:58 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
