Calculating Power number of stirred vessel
Old   June 6, 2023, 07:43
Default Calculating Power number of stirred vessel
Joe walker
Joe walker1 is on a distinguished road
I am simulating a 2D planar baffled mixing tank with a rushton turbine as the agitator, and I'm having difficulties getting Power number values from from torque. Using the equation
Np= 2*pi*N*m*torque/(Diameter^5)*density*N^3
m=number-of-blades, N=rotational-speed ,
I am using the calculating torque from a moment plot on the impeller blades, which I assume means that is the total torque thus m=1 instead of 6.
This still results in my solution converging around Np=16.6. Eventhough standard Np for the test case is ~5.
My question is, is this difference explainable from simplifying 3D to 2D, or have I made an error somewhere.
Any help is greatly appreciated
Joe walker1 is offline   Reply With Quote
fluent, power coefficient, power consumption, power number, stirred vessel
use the message in macro DEFINE_PROFILE with parallel processor alireza_T Fluent UDF and Scheme Programming 3 May 11, 2022 02:08
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
