Battery modeling with mixture model enabled
Old   July 19, 2023, 13:01
Default Battery modeling with mixture model enabled
Iason
ch09067 is on a distinguished road
Hello everyone,
I am trying to simulate the cooling of a battery by means of a fluid that undergoes a phase change from liquid to vapour. For this reason, I want to use the MSMS model for the battery and the mixture model for the two-phase flow and phase change.
I notice that in the version I am running, 2022R1 these two models are not compatible and as soon as I turn on the multiphase model the battery is turned off. On the contrary, if I run it in 2020R1 this does not happen and the modeling can be done normally.
Since I now have access to the latest version, 2022R1, I want to ask if there is a way to be able to use both of these models at the same time.
Thank you in advance for your assistance
ch09067 is online now   Reply With Quote
battery modelling, mixture model, msmd battery, multiphase model
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 18:19
Difference between Mixture & Eulerian multiphase ? Shankar FLUENT 6 October 7, 2015 08:45
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
mixture model, sand transport rayolau FLUENT 0 September 18, 2012 13:34
species transport model or mixture model?HELP zhhjll FLUENT 3 March 5, 2011 15:27
