Fleunt dynamic mesh, remeshing problem on boundarys
Old   July 20, 2023, 13:35
Default Fleunt dynamic mesh, remeshing problem on boundarys
Duke711 is on a distinguished road
In fleunt dynamic mesh option the remeshing does not work in boundary by deforming wall. See what happend, some people here seem to have had this problem.
The boundary cells on defined deforming wall only ceep stretching, not remeshing. Same problem on 2D Mesh. I think it is a bug. Dynamic mesh option is smoothing and remeshing with maximum cell local size with 1 mm.
Was someone able to solve the problem?
Fluent seems to have the problem with defined deforming wall by a tetrahedron mesh. In the Ansys examples shown, you always se a layering zone with hex mesh. With ist not possible here, because here overlapping the valve with the combustion chamber.
Duke711 is offline   Reply With Quote
Dynamic Mesh: Remeshing doesn´t work properly maccheese Fluent Multiphase 4 June 7, 2018 05:56
Sliding / Dynamic Mesh in heat transfer problem platzhalter FLUENT 0 May 7, 2018 05:25
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour Caster_Troy FLUENT 1 December 7, 2017 06:19
Dynamic Structured mesh around cylinder problem!!! ludosbiz Mesh Generation & Pre-Processing 2 March 23, 2016 15:15
Fluent dynamic mesh 'remeshing' method for pyramid elements DarrenC FLUENT 14 December 11, 2015 04:58
