Nusselt and friction factor validation in turbulent flow
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By buidu
Old   April 27, 2015, 15:52
Unhappy Nusselt and friction factor validation in turbulent flow
Mehdi
me.po is on a distinguished road
Hi
I've tried to simulate a classical problem of flow and heat transfer in a circular tube with constant heat flux, radius of 10mm and 60mm length. I've used the periodic boundary condition, K-epsilon model with st. wall function and the Reynolds number between 10000 to 40000. When I use the finer mesh, the friction factor and Nusselt increase drastically and get distance from the analytical results . This problem is more serious for low Reynolds (10000<Re<20000). I've checked several grids from 22000 to 1 billion cells, both fine and coarse, with boundary layer mesh (first layer at 10-6 m and I've also used adaption. I've even solved the problem with non-periodic condition and fully developed profile but the problem still remains. I checked the mesh with laminar velocities (and laminar model) and the results were consistent with analytical results (less than 3% error).
Please guide me to solve this problem.
me.po is offline   Reply With Quote
Old   April 27, 2015, 21:08
Lucky
This is exactly why validation & mesh sensitivity studies are always necessary.
Most likely a mesh quality problem. If your grid was automatically generated, it's probably related to increased grid skewness when you went to the finer grid.
me.po likes this.
Old   April 28, 2015, 02:23
Mehdi
Thanks,
What's your suggestion???
Old   April 28, 2015, 03:11
buidu
buidu is on a distinguished road
The turbulence intensity may have influence on the convective coefficient. The empirical equations are on the assumption that TI is very low. You can find it on textbook. From you simulation, you can also notice it.
Perhaps you can try to run your case on lower TI.
me.po likes this.
buidu is offline   Reply With Quote
Old   April 28, 2015, 04:48
Mehdi
Thank you for your advice,
Yes, it's too high. My turbulence intensity is Min 50% (at core region) and Max 91% (at wall). How can I control TI in periodic domain?
Old   April 28, 2015, 12:11
buidu
You can control your TI in the setting of inlet.
Regards
Old   April 28, 2015, 12:42
Mehdi
But that wasn't the cause of the error. when you use periodic conditions, there is no longer any inlet or outlet and flow is fully developed. I checked the problem with finer mesh with very good quality and the problem still remains!!!!!!!!!!!!!!!!!!
Old   July 24, 2023, 03:16
Default did this problem is solved?
Vaibhav Hiwale
vaibhavhiwale is on a distinguished road
Did this problem is solved? im also facing the same problem
vaibhavhiwale is offline   Reply With Quote
caculation of friction factor Dilip Main CFD Forum 9 February 23, 2016 05:00
Calculation of Friction Factor & Nusselt Number mypassion59 FLUENT 1 July 9, 2014 14:31
Getting (Nusselt vs Re) & (friction vs Re) in a ribbed duct shayan_mv FLUENT 6 November 14, 2012 03:42
Nusselt numbers for fully developed laminar flow Danro Siemens 8 July 19, 2012 07:22
