How to skip Fluent Launcher and Launching Fluent Directly from Command Line
Old   July 31, 2023, 07:03
Default How to skip Fluent Launcher and Launching Fluent Directly from Command Line
lbj007 is on a distinguished road
As it stands, whenever I execute the command in the command prompt, it automatically opens the Fluent Launcher, requiring me to manually click on the "Start" button to proceed to the Fluent application. I want to skip the click action and open Fluent directly.
lbj007 is offline   Reply With Quote
Old   July 31, 2023, 09:15
Lucky
You need to modify two environmental variables one of which is simply adding the fluent executable to the path. There is setenv.exe utility in one of the ansys dirs that will do it for you automatically.
c:\ Program files\ANSYS Inc\vxxxx\fluent\ntbin\win64\setenv.exe
Since your command line works with the launcher, it seems you may have already done this step.
Have you tried passing the nogui flag?
Old   August 3, 2023, 07:08
yes, I've already added the fluent executable to the path. I have also tried -g option, but the launcher still shows.
Old   August 3, 2023, 09:24
Lucky
If you pass -g flag then it should most certainly not launch the launcher unless there is something in your journal file that calls for the gui and then fails. Make sure you have only TUI commands and nothing that even looks like cx
Old   August 3, 2023, 10:18
I've found what is the problem, I use -3ddp, actually it should be 3ddp, It's weird not showing any mistake.
Old   August 20, 2023, 02:53
cons013 is on a distinguished road
Worked for me as well, thanks for this!!
cons013 is offline   Reply With Quote
fluent
Fluent launcher Er.spcwlkr FLUENT 0 May 1, 2019 04:09
