Automaticly read journal file
Old   September 22, 2023, 11:59
Question Automaticly read journal file
Marc
alphaNOVA is on a distinguished road
i am relatively new to fluent and am currently working on a parametric study. My workbench setup brings a parameter specific geometry (that is then meshed and the mesh then) into a fluent case. I want to control the way the case is initialised (reason for this is that i want to initialise the fluid domain from the farfield and then interpolate a file onto only one interior of my mesh). According to other posts in this forum the best way to do that is writing a journal. I created one that seems to work but now i have the problem of how to run it automatically.
I found old videos where ppl selected the journal in the fluent launcher, but i dont see any option in doing so in R2023R2.
So how do i get fluent to automatically execute my journal when im updating all the design points? I also tried using the Automatically Initialize and Modify Case functionallity as well but i cant get it to work with a design study.
My commands were the following:
Pre Intialization:
solve initialize com-def pressure-far-field
Original Settings:
file int z-s interior-chamber (interior-chamber is the region i want to interpolate my solution to, rest of the fluid domain i want to be untouched and have the values of the standart intialisation based on the pressure-farfield)
/file int r-d ok "filepath\thruster_subsonic.ip" (i tried running the command with the ok and without - i get the idea of why it askes me if i want to override but im not sure when exactly it does that, i think my main confusion is when the system will perform the standart initialization)
It works when i hit calculate manually - but not when i want workbench "update" to run the calculation. Then it tells me solution failed (the exact same case and settings run when i start it manually).
If there is any other way to initialize the case the way i need (so farfield for the entire domain and then interpolate one file onto a single interior region) that would also be totally fine for me, i just need some way to get this initialization to work. Thanks a lot!
alphaNOVA is offline   Reply With Quote
design ponts, fluent, journal, parameter, workbench
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
